Community Member
webVPN
I am testing the webVPN with a VPN 3030 box and MS IE 6.0. Everything looks good, until I try to browse to an HTTPS website. For instance, I am at keybank.com, trying to go to the login page, which is an https page. Get an error" server may not exist or access not allowed".
I have allowed everything right now, so it should let me go to any website, right?
Any ideas?
Community Member
Re: webVPN
Did you generate the certificate for the concentrator. Under Managment, certificates, I think.
Community Member
Re: webVPN
Yes. However, I do think the issue is related to the self-signed certificate. Cause some HTTPS websites work OK, and some don't. I opened a case with TAC last week.
Community Member
Re: webVPN
Check to make sure you have DNS server setup under
Configuration | System | Servers | DNS
Community Member
Re: webVPN
DNS is good. I can get to HTTP sites, it's just some HTTPS sites. TAC just said it might be Active Control settings, that are not allowed on the webVPN
Community Member
Re: webVPN
I can get to HTTPS sites it's just some java based applications that don't work through web vpn. pix pdm, switch gui interface, and wlse interface all do not work through web vpn. I got https to working by re-generating the certificate on the concentrator.
According to Cisco, some Java based applications will not work.
110
