when creating a second IPSEC tunnel the first one drops
Hi ,
here is my design:
VPN clients-----router -----------PIX
it is impossible for me to have two tunnels at the same time!
the message i get on the first client is "The remote peer has terminated your VPN connection".
the second client is connected!
Here is debug on PIX when the second client connects:
medibeg-Loos#
medibeg-Loos# sh isa sa
Total : 0
Embryonic : 0
dst src state pending created
medibeg-Loos#
ISAKMP: Deleting peer node for 213.118.68.208
crypto_isakmp_process_block: src 217.136.217.127, dest Outside-Address
VPN Peer: ISAKMP: Added new peer: ip:217.136.217.127 Total VPN Peers:1
VPN Peer: ISAKMP: Peer ip:217.136.217.127 Ref cnt incremented to:1 Total VPN Peers:1
OAK_AG exchange
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 8 policy
ISAKMP: encryption... What? 7?
ISAKMP: hash SHA
ISAKMP: default group 2
ISAKMP: extended auth pre-share
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x20 0xc4 0x9b
ISAKMP: attribute 3584
ISAKMP (0): atts are not acceptable. Next payload is 3
ISAKMP (0): Checking ISAKMP transform 2 against priority 8 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 3 against priority 8 policy
ISAKMP: hash SHA
ISAKMP: auth pre-share
ISAKMP (0): Checking ISAKMP transform 4 against priority 8 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 5 against priority 8 policy
ISAKMP: hash SHA
ISAKMP (0): Checking ISAKMP transform 6 against priority 8 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 7 against priority 8 policy
ISAKMP: hash SHA
ISAKMP (0): Checking ISAKMP transform 8 against priority 8 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 9 against priority 8 policy
ISAKMP: hash SHA
OAK_AG exchange
OAK_QM exchange
oakley_process_quick_mode:
VPN Peer: ISAKMP: Peer ip:217.136.217.127 Ref cnt incremented to:4 Total VPN Peers:1
OAK_AG exchange
ISAKMP: hash SHA
ISAKMP: hash MD5
ISAKMP: hash SHA
ISAKMP: hash MD5
ISAKMP: hash SHA
ISAKMP: hash MD5
ISAKMP: hash SHA
ISAKMP: hash MD5
ISAKMP: hash SHA
OAK_AG exchange
ISAKMP_TRANSACTION exchange
ISAKMP (0:0): processing transaction payload from 217.136.217.127. message ID = 2158345932
ISAKMP: Config payload CFG_REQUEST
ISAKMP (0:0): checking request:
ISAKMP: attribute IP4_ADDRESS (1)
ISAKMP: attribute IP4_NETMASK (2)
ISAKMP: attribute IP4_DNS (3)
ISAKMP: attribute IP4_NBNS (4)
ISAKMP: attribute ADDRESS_EXPIRY (5)
OAK_QM exchange
OAK_QM exchange
ISADB: reaper checking SA 0x80a72928, conn_id = 0
ISADB: reaper checking SA 0x80a713a0, conn_id = 0 DELETE IT!
VPN Peer: ISAKMP: Peer ip:217.136.217.127 Ref cnt decremented to:3 Total VPN Peers:1IPSEC(key_engine): got a queue event...
IPSEC(key_engine_delete_sas): rec'd delete notify from ISAKMP
IPSEC(key_engine_delete_sas): delete all SAs shared with 217.136.217.127
VPN Peer: IPSEC: Peer ip:217.136.217.127 Decrementing Ref cnt to:2 Total VPN Peers:1
medibeg-Loos#
medibeg-Loos#
medibeg-Loos#
Total : 1
Embryonic : 0
Outside-Address 217.136.217.127 QM_IDLE 0 1
medibeg-Loos# sh isa sapsa sasa sa
interface: outside
Crypto map tag: cms-standard, local addr. Outside-Address
local ident (addr/mask/prot/port): (oXya-Medibeg/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (LAN-Medibeg_wvg/255.255.255.0/0/0)
current_peer: 194.242.184.73
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: Outside-Address, remote crypto endpt.: 194.242.184.73
path mtu 1492, ipsec overhead 0, media mtu 1492
current outbound spi: 0
inbound esp sas:
inbound ah sas:
<--- More --->
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
medibeg-Loos#
medibeg-Loos#
medibeg-Loos#
What's going on ?
  • Other Security Subjects
Re: when creating a second IPSEC tunnel the first one drops
If they both connect just fine, sounds like a NAT/PAT issue. You show client-router-pix as your design. Are you doing PAT for your clients on the router? You will need to have static 1-to1 NAT translations. If this is just in your lab, turn NAT/PAT off and use your default gateways for routing.
Kurtis Durrett
we ran into the same thing. The client works best with tcp connection and make sure they have a cble/dsl router that can handle multiple tunnels. We have as much as 8 tunnels running through one link sys
Hi Kurtis,
Do you agree with the following:
I am assuming that the local lan has a private subnet and the internet facing side of the router has one offical ip address.
Further assuming the router is configured to do source address pat/natting to its own internet facing ip address.
Now when a client initates a vpn connection and no SAs are in place in the first instance IKE/ISAKMP will be invoked.
As we know ISAKMP packets are designed to use UDP 500 as destination but unfortunaletly also as source port. How would a patting device be able to distinguish client A's UDP source port 500 from client B's? Well it can't.
Now the cisco guy suggests to do a natting for each client to one "internet address" as I understand, so you would have to provide additional "internet addresses".
Now the packet arrives at the pix and the pix needs to know who it is talking to in terms of identity to be able to look up keys. Now this identity is bound to an ip address so this is why we have to use static translation.
I think it should be possible to use dynamic translation and configure wildcard keys on the pix if pre-shared keys is used as authentication method, as an alternativ to static translation.
Alternatively you could have the router do the ipsec on behalf of the clients.
The reason that PAT doesn't work with IPSEC is a OSI issue. PAT works at layer 4 of the OSI model whereas ESP, the protocol that ipsec uses, works at the network layer, layer 3. When connecting to a concentrator the clients have the ability to use layer 4, PAT, to connect with it as a feature which is negotiated. PIX and routers will be able to do this as well soon enough. You can configure wildcard keys on the pix, but when connecting your 3.x client to it you loose all the group features. But you still will NOT be able to connect to the pix unless you are being staticly translated or have some other feature on the PAT device such as nat traversal. If your running 12.2.8T(might be little bit earlier) on your router, you can staticly map the protocol ESP to a single address. This will alllow you to connect one client through the PAT device to the remote end.
Your other option is like you said, set up a L2L tunnel and its all good.
Kurtis Durrett
92
