when vpn and routing will be supported in security context
hi there to all. don't u think the context is still in premature mode. i mean it doens't support routing ,multicast,qos and vpns especially. do u think or have any idea that cisco will implement these features very soon in the box to make it a fully functional virtual firewall.like netscreen virtual system and checkpoint's virtual security gateways they are fully functional virtual firewalls. thank u
sebastan
1 REPLY
Silver
Re: when vpn and routing will be supported in security context
I think the pix already supported RIP and IGRP.But the latest versions of pix supports OSPF.
If you check into the features and data sheets of pix in cisco website, you can find the supporting features.
237
