04-13-2010 06:10 AM - edited 03-09-2019 10:55 PM
When will Cisco Security Agent 6.0.2 be released? We need to get off the 32-bit OS and onto Windows 2008 64-bit OS.
Solved! Go to Solution.
04-13-2010 06:28 AM
Scheduled for sometime this month.
04-13-2010 06:28 AM
05-04-2010 09:19 AM
Is there any plan to roll out a version of CSA that supports 64-bit Microsoft SQL Server? If so, when?
05-05-2010 10:22 AM
Where do you mean, locally on the csamc or external db, or just on servers running a ms sql 64bit db ?
05-05-2010 10:32 AM
I want to house the CSA database on a remote server running SQL 2005 64-bit. When/will will this be supported?
05-05-2010 11:26 PM
Don't think it's in the roadmap to be supported. You might want to check with your Account Manager.
