why is no ip-traffic through these config possible ? [cisco 871 router]
hi there,
i'Ve set up an incoming and outgoing acesslist of the fastehernet4 interface (external interface) which only allows ip-traffic over port 500 and 4500 udp to establish vpn over udp.
connecting the easyvpn-server works propperly, only ip-traffic like ping oder dns-lookups is denied.
may the accessliste cause this problem ? is the vpn-tunnel on fe04 terminated ??
sdm extends the accesslist with granting the ip-adresses from the vpn-server access. question: must-have oder security-whole ??
interface FastEthernet4
description $ETH-LAN$
ip address 111.222.333.444 255.255.255.248
ip access-group allow_only_ipsec_in in
ip access-group allow_only_ipsec_out out
duplex auto
speed auto
crypto map SDM_CMAP_1
ip access-list extended allow_only_ipsec_in
permit udp any host 111.222.333.444 eq isakmp
permit udp any host 111.222.333.444 eq non500-isakmp
deny ip any any
ip access-list extended allow_only_ipsec_out
permit udp host 111.222.333.444 eq isakmp any eq isakmp
permit udp host 111.222.333.444 eq non500-isakmp any eq non500-isakmp
deny ip any any
111.222.333.444 stands for the public ip-adresse.
kind regards, martin
1 REPLY
Silver
Re: why is no ip-traffic through these config possible ? [cisco
Martin
Can you also permit esp traffic in the access-list ? Also the order of operation on the interface is access-list first and then IPSec checking and encryption. I would suggest doing GRE over IPSec in this setup.
http://www.cisco.com/warp/public/556/5.html
Let me know if it works otherwise. I am talking theoretically here.
103
