Wireless - Linksys to Pix with cisco vpn client - routes fail
lloyd
I am having problems keeping the routing up on my client when using the linksys wireless - If I connect via patch and ethernet port on the linksys- routing stays up, but if I try to use the linksys wireless card the routing fails - in both cases the padlock stays - Any help, direction would be appreciated...
Also - my email address is lloyd@jdvhospitality.com not the above link
s-doyle
Level 3
Level 3
Lloyd,
Sounds like an arp problem or something. Have you checked with Linksys to see if there are any known issues?
