09-01-2003 11:11 AM - edited 03-09-2019 04:37 AM
Dear PIX Gurus,
I have a www server configured in inside. Have a static translation to the www server and also created an access list to permit www to the server. But still cannot browse the www from inside nor outside.
Any links for this?
Many Thanks,
HATO
09-01-2003 11:28 AM
Can you post your config for troubleshoot ?
Tony
09-03-2003 05:21 AM
Building configuration...
: Saved
PIX Version 6.3(2)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname PIXFirewall
domain-name perkom.co.id
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list compiled
access-list acl_in permit tcp any host xxx.xxx.xxx.135 eq www log
pager lines 24
logging on
logging timestamp
logging console debugging
logging buffered debugging
logging trap debugging
mtu outside 1500
mtu inside 1500
ip address outside xxx.xxx.xxx.140 255.255.255.240
ip address inside 192.168.10.1 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip audit name Info info action alarm drop reset
ip audit name Attack attack action alarm drop reset
ip audit info action alarm
ip audit attack action alarm
arp timeout 14400
global (outside) 1 xxx.xxx.xxx.139
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
alias (inside) 192.168.10.35 202.169.39.135 255.255.255.255
static (inside,outside) xxx.xxx.xxx.135 192.168.10.35 netmask 255.255.255.255 0 0
access-group acl_in in interface outside
route outside 0.0.0.0 0.0.0.0 gateway 1
timeout xlate 2:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
floodguard enable
ssh timeout 5
console timeout 0
terminal width 80
: end
[OK]
BEst Regards,
HATO
09-03-2003 06:24 AM
I don't find any other reference to "gateway 1" in your config. This one must point to the ISP's router interface.
Ben
09-03-2003 11:29 PM
Thank You for your quick response. Yes....it's work now. Can you tell me how the alias work? if I clear the alias. Inside users cannot access to the webserver.
Can we specify a range of ports in PIX?
Many THanks,
HATO
09-01-2003 12:44 PM
Accessing your web server from inside or outside means 2 differents and independent configuration.
First: Outside. You need the trio static/access-list/access-group.
Second: To access your server from inside. You should be able to access it directly using his inside IP address. Now, the rest of the solution depends of your DNS server(s), is there an inside DNS server who served inside users only and and outside DNS serving the Web server OR only outside DNS server serving both inside users (resolution) and Web server. The way you are using the DNS will give you the solution. If you tell us a little more about your DNS(es), we will be able to help you more.
Ben
09-02-2003 07:40 PM
We used ISP DNS, so consider outside DNS.
