Community Member
xlate
does sh xlate shows the active translation....
Community Member
Re: xlate
yes
Gold
Re: xlate
also check out the command "sh conn", which provides more info on the actuall data flow.
Community Member
Re: xlate
if you want to do more testing then you can do one thing.
clear the xlate entery only for your required server ip address.
after pushing this command your connection of server should be break.
show connection is also a better way to check your connectivity.
109
