XLATEs not timing out
Has anyone had experience with XLATEs not timing out? I'm using PAT on a PIX 525 for approx 100 users. This has been working fine for a year. Recently I've been forced to do a clear xlate on every other day to free up connections on our patted address. We can get to 100,000 xlates before we hit the limit.
1 ACCEPTED SOLUTION
Re: XLATEs not timing out
Sounds like a bug, take a look at CSCdy58717.
From the bug:
Workaround:
- If this condition takes long time to develop, for example, if this issue only occurs several weeks after PIX reloads, then reloading PIX is the proper workaround.
- If this condition takes shorter time to develop, say, only a couple of days after PIX reloads, or if frequent reload is not a feasible workaround, then 'clear xlate' is the proper workaround. If even 'clear xlate' does not clear all non-timing out connections, use 'clear local-host'.
- Use a version below 6.2 (or download the beta 6.3(0.124) as Cisco says it's fixed in that code, but good luck with that one!) .
Hope it helps.
Steve
1 REPLY
From the bug:
Workaround:
Hope it helps.
Steve
109
