7600 PPPoE on range C-Tags
Hi All,
I am trying to do PPPoE on a range of C-Tag (QinQ inner vlans) on 7606  with ES+ card. This is quite easy on the 7200/7300 series routers, as  such:
interface GigabitEthernet0/3.2528
  encapsulation dot1Q 2528 second-dot1q 100-200
  pppoe enable group TEST
This seems to be impossible on the 7600. It doesn't take vlan range on the second-dot1q.
TEST-7606(config)#int GigabitEthernet3/1.10
TEST-7606(config-subif)#encapsulation dot1Q 10 second-dot1q ?
   <1-4095>  Second (inner) 802.1Q VLAN ID
I also tried by using the EVC, PPPoE is not available under the EVC configuration mode.
TEST-7606(config-if)#service instance 10 ethernet
TEST-7606(config-if-srv)#ppp?
% Unrecognized command
I am running 122-33.SRE6 advanced IP IOS.
Can anyone please give some advices?
Any help would be appreciated
Jing
1 REPLY
Hi Jing, I have the same
Hi Jing, I have the same problem.
Was you able to find a way to run pppoe for inner vlans in a service instance?
Regards.
668
