Correct Configuation for 7206VXR with PPPoE??
I have been tasked with setting up our first PPPoE DSL connection. We have it up and running, but the speeds seem to be rather slow, and would like someone to review the config and see if I am missing something that would improve the overall speed of the pppoe connections. During download tests, we found that we would drop from 12MB(standard ethernet) to 4.5MB (PPPoE). So any help would be appreciated. Here is relevant information:
7206vxr with a NPE-G1 Card
Version: c7200-advipservicesk9_li-mz.124-20.T1
Relevant Configuration information:
bba-group pppoe global
virtual-template 41
sessions per-mac limit 2
interface Loopback41
ip address 192.168.41.1 255.255.255.255
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
media-type rj45
no negotiation auto
interface GigabitEthernet0/2.2
description DSL-Data Traffic
encapsulation dot1Q 4
pppoe enable group global
interface Virtual-Template41
description New Subnet 41 Behind Occam
mtu 1454
ip unnumbered Loopback41
no ip route-cache cef
no ip route-cache
ip tcp adjust-mss 1414
no logging event link-status
load-interval 30
no peer default ip address
ppp authentication pap
Re: Correct Configuation for 7206VXR with PPPoE??
enable cef on the PPPoe aggrigation interface then you will see it is improved
Why is MTU so less, i think 1492 would be ok, also tcp max should be 1452, try to tune those and see if performance increases..
also as described above, enable CEF on the interface
We're experiencing somewhat similiar problems -- we're going to compare between PPPoA and PPPoE.  What did you ever find out?
Frank
353
