Community Member
problem in cisco boot
I faced with a general problem ,
I have loaded an IOS in as5350 and boot the system with it , but as my device does not support it ,
my gateway is restarted continually and I couldnt access it even I couid not use reset factory .
what should I do is it correct with power off/on ?
1 REPLY
Community Member
Hi all,
reload the device, if the boot doesn't work again
then reload it and push it the ROMMON, then fix the boot image.
let me know if that solved your problem.
480
