Regular Expressions Help - Limiting to Two ASN Prepending
I want to limit a incoming advertisement in BGP to allowing a maximum of Two ASN's both of which may be prepended.
Need some help with the regular expression.
I have the regular expression that shows only the two ASN's I want that can both be prepended.
Basically I want a customer to be able to advertise their ASN and customer ASN's, but if they don't tell us about customer/customer asn's want to be able to block these from coming into my network;
ISP1#show ip bgp regexp ^(60000_)+(59000+)
BGP table version is 56, local router ID is 172.6.101.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 10.0.180.0/24    172.6.100.2                            0 60000 60000 59000 59000 59000 59000 ?
*> 10.0.250.0/24    172.6.100.2                            0 60000 60000 59000 59000 59000 59000 ?
*> 192.168.230.0    172.6.100.2                            0 60000 60000 59000 59000 59000 59000 57000 ?  <---- want to exclude this one
*> 192.168.250.0/32 172.6.100.2                            0 60000 60000 59000 59000 59000 59000 ?
*> 192.168.250.1/32 172.6.100.2                            0 60000 60000 59000 59000 59000 59000 i
*> 192.168.251.1/32 172.6.100.2                            0 60000 60000 59000 59000 59000 59000 ?
I though it would be something like this
^(60000_)+(59000+)$), but does not work
Any help appreciated.
1 REPLY
What if you just check
What if you just check "ending in 59000"?
44
