Community Member
setting PPPoE clients speed Via Cisco router
Hi i have a 7200 cisco router working as NAS (network access server) for PPPoE sessions , the clients connected DSLAMS and the Cisco connected to an AAA external Raduis server.
i want to set the user speed Via cisco router in a way which can be controlled in the Radius server , and not through the actual speed of the DSLAMS ports
Thanks alot
1 REPLY
Hall of Fame Super Silver
Re: setting PPPoE clients speed Via Cisco router
Hello Mohamed,
there is a feature called controlled subscriber bandwidth that may fit your needs:
see
http://www.cisco.com/en/US/docs/ios/bbdsl/configuration/guide/bba_con_sub_bdwth_ps6441_TSD_Products_Configuration_Guide_Chapter.html
it manipulates the ATM traffic parameters on a per user basis
these settings can be done on radius AV:
example:
The following example shows how to configure RADIUS attributes for a user profile for DBS:
user1@cisco.com Password = "userpassword1", Service-Type = Outbound
     Service-Type = Outbound,
     Cisco-Avpair = "vpdn:tunnel-id=tunnel33",
     Cisco-Avpair = "vpdn:tunnel-type=l2tp",
     Cisco-Avpair = "vpdn:l2tp-tunnel-password=password2",
     Cisco-Avpair = "vpdn:ip-addresses=172.16.0.0",
     Cisco-Avpair = "atm:peak-cell-rate=155000",
     Cisco-Avpair = "atm:sustainable-cell-rate=155000"
Hope to help
Giuseppe
743
