1020 Drop connections on B, not A
We are deploying AP1020s and are having problems with users dropping connections on B. If I connect with a device that uses A, it will stay up no problem.
The 1250s are an upgrade to our 350 series APs. If we go back to the 350 series, everything works fine on B.
I need B since most of our devices don't have A nics. Any thoughts?
1 REPLY
Re: 1020 Drop connections on B, not A
These B radios should work fine.
I would make sure you are on the later IOS codes.
Something like 12.3(8)JA.
It sounds like the RF environment is fine because when you replace the units with the 350s it works fine. If this is seen on all of the AP1200s I would say it is a code issue.
Hope this helps.
Aaron
107
