09-30-2005 03:23 AM - edited 07-04-2021 11:10 AM
After upgrading to 12.3(4)JA1 AP is unable to register with WDS.
Downgrade back to 12.3(2) solves the problem.
Did anybody experience this problem?
09-30-2005 05:34 AM
You are most likely experiencing this bug:
CSCsa90418
Externally found moderate defect: Verified (V)
12.3(4)JA WDS does not authenticate WLSE due to incomplete arp entry
Workaround(s):
1) Turn on proxy arp (ip proxy-arp) on the router that is the first hop from the AP-WDS to the WLSE OR
2) If proxy arp cannot be enabled for some reason, then create a static arp entry on the AP.
The bug was seen with 2.11 and 12.3(4)JA but we have seen it with other versions as well.
10-03-2005 03:28 AM
I don't use a AP as WDS. I use WLSM.
Unfortunaly I can't verify arp entries at the moment, but I might do this later and post results, if somebody interested.
