Community Member
1100 AP - WEP 128 : do not forward DHCP
We've got some Cisco 1100 AP who we configure with a static IP, and a 128bit WEP key.
After we actived the wep key we don't receive an ip address on the clients.
We are getting authenticated, but that's it.
When we use no security , everything works well.
I allready fill in the wep key through the cli - no luck
Upgrading to latest IOS (123-7.JA1) also had no succes.
Anyone has some hints/tips what I'am doing wrong?
I can't believe this is a bug ?
Super Bronze
Re: 1100 AP - WEP 128 : do not forward DHCP
I believe that you are possibly not correctly entering the WEP key on one end - I'd suggest putting it into a notepad doc, and pasting it into both the AP and your client config...
Make sure you don't put in a trailing space or anything that might confuse it - also check whether your client expects ASCII or HEX keys..
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
I did lot's of thing to make sure the WEP key was correct. I'am sure of it this aint the problem.
Nobody else got problems with WEP128 and DHCP ?
cheers,
Community Member
If you put a static IP address on the client, are you able to ping the AP and the rest of the wired/wireless network?
Community Member
I am having the exact same issue. Is there a resolution to this issue?
Community Member
There is no bug, make sure that the tipe of key is correct (HEX or ASCII) as well as the key itself.
One thing I've noticed on several occaisions is that although you enter the WEP key in the GUI if you look at the text config (telnet to the AP and do a sho run) it's not there! Either enter the key from the CLI or keep re-entering through the GUI until it appears in the config. The effect of this problem is exactly as you describe.
330
