1130 WPA-PSK Radius Mac Authentication
I am trying to get our Cisco 1130 AP's to use Radius MAC Authentication using a freeradius server. We have been successful with other AP's (Proxim, Netgear) but haven't been able to get the Cisco 1130 to work.
I have attached 2 files. One is the running config, and the other is a debug of radius.
This is what the freeradius log says.
Thu Nov 6 02:48:46 2008 : Auth: Login OK: [004096a3e012/004096a3e012] (from client 10.80.0.17 port 291 cli 00-40-96-A3-E0-12)
I would appreciate any help that anyone is willing to give.
Silver
Re: 1130 WPA-PSK Radius Mac Authentication
Use the wpa-psk SSID interface configuration command to configure a pre-shared key for use in WPA authenticated key management. To support WPA on a wireless LAN where 802.1x-based authentication is not available, you must configure a pre-shared key for the SSID.
wpa-psk { hex | ascii } [ 0 | 7 ] encryption-key
but make sure that This command is not supported on bridges.
I get this error.
Error: WPA-PSK not supported with MAC address authentication configured
896
