Community Member
1130AG AP can not get a join controller
Hi, I have just connected my 1130ag ap to the network noticed that it can not get a Join response. as follows;
bymydesk#
*Mar 1 00:00:25.294: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:35.698: LWAPP_CLIENT_ERROR_DEBUG: spamHandleDiscoveryTimer : Found the disco
very response from MASTER Mwar
*Mar 1 00:00:35.707: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Mar 1 00:00:40.707: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not recieve the J
oin response
*Mar 1 00:00:40.707: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses remain.
*Mar 1 00:00:40.746: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID
NOT GET JOIN RESPONSE.
*Mar 1 00:00:40.746: %LWAPP-5-CHANGED: LWAPP changed state to DOWNXmodem file system is
I have looked in the forum and other people have had the problem and have indicated it could be a date time issue. I have set the date and time but when I do a "show Auth-list" i get nothing back like the following;
(Cisco Controller) >show auth-list
can anyone help please, i am not sure what else to do
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: 1130AG AP can not get a join controller
That is fine. Is the management and ap-manager both on vlan 60? Also they should be untaged and the switchport should be native vlan 60.
-Scott
Did you upgrade the 1130 from IOS to LWAPP? If so you might need to add the SSC to the WLC.
-Scott
Community Member
Hi Fella5,
no this was not upgraded, it was just a out of the box AP
Capture the output from when you boot up the ap and post it. I would like to see the log from when the ap boots up.
-Scott
Community Member
hi, the bootup capture as follows;
bymydesk#Xmodem file system is available.
flashfs[0]: 3 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 1870336
flashfs[0]: Bytes available: 14128640
flashfs[0]: flashfs fsck took 24 seconds.
Base ethernet MAC Address: 00:19:06:73:30:90
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx"...#####################################
File "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx" uncompressed and installed, entry point: 0
x3000
Software clause at DFARS sec. 252.227-7013.
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWAR
E (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:38 by alnguyen
Image text-base: 0x00003000, data-base: 0x0035E440
Initializing flashfs...
flashfs[1]: 3 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 1870336
flashfs[1]: Bytes available: 14128640
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
cisco AIR-LAP1131AG-E-K9 (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes
of memory.
Processor board ID FCZ1032Q0BR
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Part Number : 73-8962-09
PCA Assembly Number : 800-24818-08
PCA Revision Number : A0
PCB Serial Number : FOC10303LP1
Top Assembly Part Number : 800-25544-06
Top Assembly Serial Number : FCZ1032Q0BR
Top Revision Number : A0
Product/Model Number : AIR-LAP1131AG-E-K9
Press RETURN to get started!
*Mar 1 00:00:06.192: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar 1 00:00:06.201: %SYS-5-RESTART: System restarted --
E (fc1)
*Mar 1 00:00:07.157: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:08.157: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, chang
ed state to up
ed state to up
*Mar 1 00:00:25.221: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:35.632: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Mar 1 00:00:40.632: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not recieve the J
oin response
*Mar 1 00:00:40.632: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses remain.
*Mar 1 00:00:40.673: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID
*Mar 1 00:00:40.674: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
Doesn't look like the ap is getting an ip address. You usually see the ap getting a dhcp unless it has a static. Also the ap doesn't try to use DNS to resolve. Is you wlc setup for layer 3 or layer 2.
post your show run-config.
-Scott
Community Member
it is using the layer 3 option, also i have not configured the dns server under the dhcp scope, will this have any effects?
-Scott
380
