1131 access point intermittently stops responding
We have an 17 offices with the same basic wireless config. 2 or 3 ap's with the same configuration on them. This one particular office has 2 ap's that intermittently will stop responding to pings and are no longer reachable via telnet or http and users cannot connect through the ap. We are running c1130-k9w7-mx.124-3g.JA1/c1130-k9w7-mx.124-3g.JA1.
I had the site (located in Spain) send me pics of the ap's and noticed that they are not mounted, just laying on ceiling tiles in a plenum ceiling.
Once the ap's are again reachable there is nothing in the log that would suggest there was a problem and the ap does not reboot.
Any ideas?
here is the config...
ap1_spain#sh run
Building configuration...
Current configuration : 6901 bytes
! Last configuration change at 17:23:30 +0200 Tue Sep 14 2010 by dguse
! NVRAM config last updated at 17:23:30 +0200 Tue Sep 14 2010 by dguse
version 12.4
no service pad
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname ap1_spain
aaa new-model
aaa authentication login default group tacacs+ none
aaa authentication login no_aaa none
aaa authorization console
aaa authorization exec default group tacacs+ none
aaa authorization exec no_aaa none
aaa authorization commands 15 default group tacacs+ none
aaa authorization commands 15 no_aaa none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
resource policy
clock timezone +0200 2
ip subnet-zero
dot11 ssid xxxxxxxxx
   authentication open
   authentication key-management wpa
   wpa-psk ascii 7 03055908555ABA1A1A5F4D071616
dot11 network-map
power inline negotiation injector 0017.0ed7.442f
crypto pki trustpoint TP-self-signed-1171819700
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1171819700
revocation-check none
rsakeypair TP-self-signed-1171819700
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid linvatec
power local 14
power client 14
station-role root
world-mode dot11d country ES both
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
dfs band 3 block
channel dfs
station-role root
no cdp enable
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
speed 100
full-duplex
bridge-group 1
interface BVI1
ip address 10.x.x.x 255.255.255.0
no ip route-cache
ip default-gateway 10.x.x.x
no ip http server
ip http authentication aaa login-authentication default
ip http authentication aaa exec-authorization default
ip http authentication aaa command-authorization 15 default
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server view dot11view ieee802dot11 included
snmp-server community xxxxxxxxxxxxxx RO
snmp-server location Barcelona
snmp-server chassis-id ap1_spain
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps entity
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server enable traps wlan-wep
snmp-server enable traps config-copy
snmp-server enable traps syslog
snmp-server enable traps cpu threshold
snmp-server enable traps aaa_server
tacacs-server host 10.x.x.x
tacacs-server directed-request
tacacs-server key 7 071C244F5B461C1D0D1079282A2D27222D010C
bridge 1 route ip
line con 0
login authentication no_aaa
line vty 0 4
sntp server 10.x.x.x
sntp broadcast client
end
Re: 1131 access point intermittently stops responding
     What is the switchport config of the port connected to the AP?  The AP is set to be 100/Full, if the switch isn't set as well, you could be going half-duplex and losing connecitvity due to that.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Port is set to 100 / full.
sw1_spain#sh run | begin 0/47
interface FastEthernet0/47
description ap1-spain Wireless Access Point
switchport mode access
speed 100
duplex full
Issue was resolved by moving the location of the access point a couple feet.  Not sure what was causing the issue.
538
