1152 LAP, coverage and radio settings / RF planning tool
I'm trying to limit the coverage of some access points to be able to do roaming tests between the APs, and to make small wlan zones for testing teams.
In the 5500 WLC I saw the radio settings and Power Level. Unfortunately it isn't enough, i need to lower the power. Is there another way to limit the power of an AP ? is there any documentation about how to do that ?
I saw a RF Planning Tool in some documentations, but can't find it, does it exist somewhere ?
Christophe
1 ACCEPTED SOLUTION
When you go to Wireless > Then 802.11a/n or 802.11b/g/n on the left side, you can change the power level of the AP there.
As these aer 1142, power level 1 will be 17dBm/50mW.  Every three dBm you go down halves the power, every 3 dBm up doubles the power.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Steve
I saw these parameters, so I'll try to change this from 7 to 1 to see if it's enough.
Thanks for your answers.
Christophe
1 is the highest power, you would want to go lower.
Steve
Yes sorry, just a mistake in the message.
773
