1200 in repeatermode
I have an AP 1200 that I want to configure in repeater mode, but when I do this it stops to respond to the IP address.
Traffic throw the AP works just fine, but I can’t access it via IP only buy console.
(running ios 12.2.13-JA2)
Any Ideas on what is can be?
/Regards Rikard
1 REPLY
Bronze
Re: 1200 in repeatermode
If you are trying to configure the access point via ethernet as a repeater, then once you change role in radio network to repeater, the ethernet port gets disabled. So you would need to either configure it via wireless or via console. Here are the release notes for that version of IOS http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/bu12213/b13ja2.htm
118
