01-12-2006 12:59 PM - edited 07-04-2021 11:30 AM
We currently have an Aironet 1200 running the most current IOS that we need to upgrade to use WPA2. From what I have read I need to upgrade the hardware to support WPA2 and AES. Has anyone had any experience with the upgrade? We also have some 1100 series APs that take the same hardware upgrade. Should we upgrade those also?
Thanks ahead of time for the suggestions.
John
01-12-2006 03:17 PM
If you upgrade to the current "g" radio, you'll be enabled for AES/WPA2.
You can verify your hardware revs from the Web GUI, under Interfaces | Radio 802.11G | Detailed Status.
It should be something like "Radio AIR-MP31G" (or better) for WPA2.
Installation is not too much of a headache ... I always get a little nervous with those tiny antenna connectors on the radio board ... be very careful to align them properly before applying any pressure ... they're pretty easy to damage.
Good Luck
Scott
01-12-2006 07:02 PM
Scott,
Thanks for the good news. Going to go buy the upgrade kits now.
Thanks again,
John
01-13-2006 07:10 AM
Would an AIR-AP1220B-A-K9 upgraded with AIR-MP21G-A-K9 be able to support WPA2 (AES)?
02-07-2006 07:12 AM
Have upgraded our oldest AP1200 series (with IOS)with AIR-MP21G-E-K9 and now we can use WPA2.
Have 18 AIR-MP20b radiochips in a cardbox. Probably no use for them anymore, or?
