Community Member
1200 Series...Why will some MAC addresses not Authenticate
I am running a number of AP1200's with the same problem. There comes a point that as new MAC addresses are added to the AP, the will not authenticate. In one of the lines of the FAQ, I have read that it is only possible to enter up to 40 MAC addresses using the GUI. After this you must use the command line.
Upon investigating this, I am running into a problem withthe command line config where it has an encrypted password attached to it. I never entered a password. Upon de-crypting the password I have found that it is the same as the MAC address. When I enter the user MAC and password using the command line and look at the config, the passwords I entered this way are displayed in the un-encrypted format.
My bottom line question, after all the rambling is this, how do I enter MAC addresses correctly from the command line? Example...
username 0012f00658f1 password 7 0012f00658f1
username 0012f00658f1 autocommand exit
Correct?
Thanks.
Silver
Re: 1200 Series...Why will some MAC addresses not Authenticate
Hi Terry
First, please use global command:
"service password-encryption"
And then, just try:
"username 0012f00658f1 password 0012f00658f1"
Let us know if it works. Hope this helps
Community Member
Thanks for the help, it works perfectly now.
146
