04-01-2008 06:20 AM - edited 07-03-2021 03:37 PM
I think I already know the answer to this - but I'll ask anyway. Is there any available method to upgrade older 1230B APs to G radios that are compatible with the 4400 WLCs? We've got 30 in use and that's big bucks to chunk them all in the trash and "forklift" to 1231Gs.
04-01-2008 06:44 AM
Hi Chris,
You can upgrade the 1230 if it has the proper radio as shown below;
The 1200 Series can be upgraded to LWAPP with the G Radio model listed below;
Solution Requirements
Migration from autonomous access point mode to lightweight mode is possible on these Cisco Aironet access point platforms:
All 1130AG access points
All 1240 AG access points
For all IOS-based 1200 series modular access points (**1200/1220 Cisco IOS Software Upgrade, 1210 and 1230 AP) platforms, it depends on the radio:
if 802.11G, MP21G and MP31G are supported
if 802.11A, RM21A and RM22A are supported
The 1200 series access points can be upgraded with any combination of supported radios: G only, A only, or both G and A.
From this good doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00804fc3dc.html
So you would need to install the Radio Upgrade kit to install the (AIR-MP21G-A-K9).
Cisco Aironet 1200 Series Access Point Radio Upgrade Instructions
http://www.cisco.com/en/US/docs/wireless/access_point/1200/radio/upgrade/guide/12rupgrd.html
Cisco Aironet 802.11G 1100 and 1200 Series Access Point Upgrade Kit
I'm not 100% sure that these kits are still available (but I think they are :)
Hope this helps!
Rob
04-01-2008 06:59 AM
Thank you very much! That didn't turn up in the doc search - didn't get the right terms LOL. I have the LWAPP upgrade doc, missed the note on the kit. Good deal. That'll make the boss happy.
04-01-2008 07:04 AM
Hi Chris,
You are most welcome :) It's always good to save the school some money that can go towards the Students :) This makes everyone happy.
Take care,
Rob
Please remember to rate helpful posts.....
