Community Member
1231 firmware
When trying to update from 12.3(8)JA3 to 12.3(13) JEA1 using TFTP server on 1231G AP I receive "error 123 in system call CreateFile the filename, directory name or volume label syntax is incorrect. Help..
1 REPLY
Bronze
Re: 1231 firmware
Most of the times, the problem is with incorrect download syntax at the AP. The correct syntax is:
ap# archive download-sw(space)/overwrite(space)/force-reload(space)tftp://ipaddress_of_tftp/image
Try this syntax for downloading and let me know the result. Mostly, it should be successful.
610
