1240 AG Set-up as Repeater Problems
I have two Cisco 1240AG routers. One is setup as an AP and the other is setup as a repeater to the host (AP). Both of these have static IP's in the same subnet (192.168.1.X). Once the repeater is powered up it does broadcast the signal and connect fine, but it is spitting out an IP address (169.254.X.X) that will not work within our network. I thought it would spawn DHCP through the host. Does anyone know how I can get the repeater to give an IP address of (192.168.1.X). I have tried entering in commands to point to the DHCP server and also for the DHCP IP pool, but nothing seems to work. Any suggestions would be appreciated.
Thanks!
Hall of Fame Super Silver
Re: 1240 AG Set-up as Repeater Problems
How are your ap's configured.... repeater BVI interface is on the native vlan? if you can associate to the root ap and get a dhcp, then at least we know that that side is configured right. Have you confirmed that?
-Scott
Yes, the repeater can associate to the root AP, but when I connect a handheld to the repeater it is giving me the wrong IP address. I used an IP-helper command to associate my DHCP server with the repeater, but it still gives me the wrong IP. I need it to configure an IP within the range of 192.168.X.X. It gives me an IP of 269.254.X.X. Since it is giving me an IP in the wrong pool of address's I cannot connect my handhelds to the network from the repeater. This is my first experience with Cisco routers so I do not have as much experience with them...I appreciate any suggestions you can give! Thanks!
Can you have a laptop or one of your handhelds connect to the ROOT AP first and verify that that device associates and get the correct DHCP address?
-Scott
Yes, I can connect a laptop and all of my handhelds to the root AP with the correct pool of IP addresses (192.168.X.X). As soon as I connect them to the repeater it spawns a new wrong IP (269.254.X.X)
Thanks!
The SSID you are associated to with your handheld (on the root ap), is that the same SSID your repeater ap is associating to?
-Scott
Yes it is...same SSID, same WEP encryption, and same MAC address filters.
The 169.254.x.x is a default ip address the client creates when unable to aquire a dhcp address. I would suggest you post your configurations so people can take a look.
-Scott
Below is the config file for my repeater router. If anyone can see where the problem lies I would appreciate it!
version 12.3
no service pad
service password-encryption
hostname (hidden hostname for security purposes)
enable secret 5 (deleted for security purposes)
ip subnet-zero
no aaa new-model
dot11 ssid (hidden SSID deleted for security purposes)
authentication open
guest-mode
infrastructure-ssid
power inline negotiation prestandard source
username Cisco password (deleted for security purposes)
username admin password (deleted for security purposes)
bridge irb
interface Dot11Radio0
AP# configure terminal
AP (config) # interface dotllradio 0
AP (config-if) # ssid (hidden SSID deleted for security purposes)
AP (config-ssid) # infrastructure-ssid
AP (config-ssid) # exit
AP (config-if) # station-role repeater
AP (config-if) # dot11 extensions aironet
AP (config-if) # parent (MAC address deleted for security purposes)
AP (config-if) # end
encryption key 1 size 128bit (deleted for security purposes) transmit-key
encryption mode wep mandatory
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.X.X 255.255.255.0
no ip route-cache
ip default-gateway 192.168.X.X
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
I posted the config file for my repeater router and I am still not sure why DHCP will not work correctly...if you have any ideas for me to try please let me know. Thanks!
1047
