1240AG WPA problems
Hello, I have a Cisco 1240 AG with two SSID.
One is WPA2 protected and the other WPA.
I cannot connect a Zebra QL 420 mobile printer with WPA's SSID.
The log is:
Station 00a0.f83c.cffd Authentication failed
and so
Packet to client 00a0.f83c.cffd reached max retries,  removing the client
Howewer if I connect the printer with a Access point with only one SSID WPA protected it's working fine, so in my opionion isn't a problem regarding printer's wireless setup.
the firmware is:
System Software Filename:c1240-k9w7-tar.124-10b.JA
System Software Version:12.4(10b)JA
Bootloader Version:12.4(13d)JA
the 1240 configuration is:
version 12.4
no service pad
service password-encryption
hostname ap.default.domain.invalid
enable secret 5 $1$gTb/$V5xhnuaXSAK3fOLHsaR9o1
no aaa new-model
clock timezone +0100 1
dot11 ssid betaorionis159
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
dot11 ssid inventario
   authentication open
   guest-mode
power inline negotiation prestandard source
username Cisco password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid betaorionis159
ssid inventario
channel 2412
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
no dfs band block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.16.18 255.255.255.0
no ip route-cache
ip default-gateway 192.168.16.11
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
What can I do?
My printer doesn't support WPA2, and pc's are connected with WPA2.
Please help me.
kind regards
Renis Ganz
1240AG WPA problems
Hello Renis,
I think that your printer does not understand RSN IE in the beacons and hence is not able to communicate with the WLAN.
I think things should work fine if we can turn off the RSN IE for your SSID's beacon.
I am not sure how to turn that off with autonomous APs, but you can try this under your printer's SSID:
  authentication key-management wpa optional
by adding the word "optional" to the command I hope that will turn off the RSN IE so the printer would understand better.
Please try and let us know if that helps.
If not, please provide show logging from the AP while the printer tries to connect.
Amjad
Rating useful replies is more useful than saying "Thank you"
Bronze
Re: 1240AG WPA problems
Hi , i checked the configurationa and you have configured the one ssid to work with wpa version one and the other ssid to work with wpa version 2 which is okay, but under the radio you have onky configured to use the ciper of tkip which is for wpa version 1
If you would like to work with The setup you have you should create vlans and link each vlan with the corresponding ssid and specific encryption method, if you have 2 ssids configured and not workin with lans you will have to use the same encryption method on oth ssids.
The errors that you report are see when you have configured the unit incorrectley client issues or rf interfirence.
Also if you try to configure the ap via the gui it will give you an error that you need to use to different encryption ethods on each ssid.
Bronze
Hi Renis,
If you access the AP via the GUi, click on security, then SSID manager and then on the ? on the left side you will be able to check on this information.
WPA Pre-shared Key
To support client devices using static  WEP keys                and WPA key management, you must configure a pre-shared  key on the                access point. Enter the key and choose the appropriate  radio button to specify if you are entering hexadecimal or ASCII  characters.
If you use hexadecimal, you must enter 64  hexadecimal character to complete the 256-bit key. If you use ASCII,  you must enter a minimum of 8 letters, numbers, or symbols, and the  access point expands the key for you. You can enter a maximum of 63  ASCII characters.
572
