1242 and 1220 AP ---can telnet but not web browse?
Hello ,
At my workplace we have recently updated TACACS configuration---just a new key .....and also password of last resort ---this should have gone smoothly--but some APs did not take the config for some reason----therefore myself and other employees had to visit each device and console in to update ---the majority of these worked , but a few will now not allow web browsing ---but you can telnet ---when I examined the config and software --the only difference I could see was the Boot loader was higher on the ones that cant be accessed via HTTP (12.4 (7) JA) if memory serves----whereas the AP's that work correctly have the same version 12.3(7) as the image file ( 12.3) .
Could this be the only reason ? I have checked every line of the config ,and show version---anyone else had a similar problem? Thanks in advance.
  • Other Wireless - Mobility Subjects
Re: 1242 and 1220 AP ---can telnet but not web browse?
Just to specify----I cant web browse as I am refused access , I get the username /password prompt when typing in the IP address---I have a telnet session already open and am using the password of last resort (which I know is correct ) or my TACACS username and password........thanks!
Hall of Fame Super Gold
Is HTTP/HTTPS enabled in the config?
I will have to check --thanks for replying , I will update later today
722
