03-22-2006 08:19 AM - edited 07-04-2021 11:50 AM
I've configured a root and non-root bridge, but they are not asscociating to each other.
What have i left out?? (the config of both APs are very basic, no security/authentication)
Thanks.
03-23-2006 04:51 AM
Whats the distance between the two bridges? Or they are close by and they can't associate? Need more details.
Thk,
P
03-23-2006 05:17 AM
they are just side by side (im doing an in-house testing before putting the AP on the actual location).
but, the AP's are without antenna at the moment (still waiting for the arrival), will that be the problem??
nothing complicated has been configured, just ssid and authentication open.
hope the information is enough for you to help me..
thanks.
03-23-2006 07:30 AM
The lack of antenna could be the problem. I normally use some spare "rubber ducks" to test the bridges locally.
03-23-2006 05:26 AM
I have a problem like this with AP 1310.
If there is a power outage I have to put the non-roote
AP to root and then back to non-root again to make them asscociate
03-23-2006 08:03 AM
erm..meaning i must have an antenna attached to the ap in order for the bridge association??
i'm place both the ap next to each other, arent this enough??
btw, what's the diffrence between workgroup bridge and non-root brige with the option with wireless clients (for both role) ??
thanks you.
03-23-2006 10:25 AM
A Non- root bridge connects to the root bridge and a wireless link is created. With the non-root role you are also able to have wireless clientes attached. A workgroup bridge connects to a root bridge but cannot have wirless clientes. The only clients it can have are the ones connected to the lan segment
03-23-2006 05:08 PM
okie..but how about the root/non-root association failure, im having now??
anyone can help me on that..
03-24-2006 01:07 AM
try connecting antenna to the bridges.
03-26-2006 01:49 AM
my antenna due to arrived next month, guess i can only test that later..
