1242AG WGB and Client Devices
Hi, is there a way to connect multiples AP to a root AP which is connected to the LAN and at the same time allowing client devices to connect to those AP. Perhaps, using 2.4 Ghz for client devices and 5 Ghz for WGB. Or perhaps using the AP as a repeater?
  • Other Wireless - Mobility Subjects
Re: 1242AG WGB and Client Devices
Daniel,
The simple answer is yes - the only thing that could change the way they are configured is - are you AP's LWAPP or Autonomous
HTH.
I'm using Autonomous AP, since there's no WLC.
Hall of Fame Super Silver
The only way is to setup the ap's as a repeater, which isn't a good idea, since the throughput is cut in half.
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
I agree with Scott, you a re probably best configuring the AP as a non-root or a work group bridge.
162
