1242AG when reboot stops broadcasting SSID's?
Need some advice, I have 2 SSID's set on the dot11radio0 interface each on a seperate vlan with mbssid set. All works fine. I can associate ok to either and vlan trunking is working. Whenever I power down the AP for any period of time and restart, the SSID's no longer broadcast. All interfaces are up up.
Any advice is appreciated
IOS C1240-K9W7-MX.124-10B.JA
dot11 ssid avnet
vlan 1
authentication open
dot11 ssid homenet
vlan 2
authentication open
mbssid guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 key 1 size 128bit 7 256C360B1CD135784F0448257840 transmit-key
encryption vlan 2 key 2 size 128bit 7 FD4A6BD63DE57FD26B5F05382FE2
encryption vlan 2 key 3 size 128bit 7 1C394A6BD63DE57FD26B5F05382F
encryption vlan 2 key 4 size 128bit 7 904B7305171C22031220D71D6339
encryption vlan 2 mode wep mandatory
encryption vlan 1 key 1 size 128bit 7 624CE1586C360B1CD135784F0448 transmit-key
encryption vlan 1 key 2 size 128bit 7 0E4825784036242F11302113E42E
encryption vlan 1 key 3 size 128bit 7 4F25784036242F11302113E42E50
encryption vlan 1 key 4 size 128bit 7 1D7958E50ED64CE1586C360B1CD1
encryption vlan 1 mode wep mandatory
ssid avnet
ssid homenet
mbssid
speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 192.168.0.3 255.255.255.0
no ip route-cache
Hall of Fame Super Red
Re: 1242AG when reboot stops broadcasting SSID's?
Hi Julian,
Unless I am missing something (no surprise:). It looks like only "homenet" is set to Broadcast using the "guest-mode" command;
dot11 ssid homenet
vlan 2
authentication open
mbssid guest-mode
This one "avnet" is not set to Broadcast;
dot11 ssid avnet
vlan 1
authentication open
Hope this helps!
Rob
Rob,
Thanks for your input. You are correct that I only want to guest broadcast the homenet SSID. The strange thing is that with using Netstumbler when I first build the AP config I can see both SSID's and connect to both without issue. When I have the AP sit unpowered for a couple of hours and power back on, it doesn't respond to association attempts anymore. I then have to default it and rebuild.
Hi Julian,
That is very strange indeed! What IOS are you running? Are you remembering to Write your config changes?
Rob
Hi Rob,
I'm running c870-advsecurityk9-mz.124-15.T1
Yep, writing to startup. I have experienced the same thing on 2 different AP's
David
310
