1250 AP - 40mhz channel selection issue
Every time I try to enable the 40mhz channel bonding for the 5ghz radio I receive the following error message, "slot is not disabled or customize is not enabled". This occurs from both the web and CLI interface.
Thanks.
Steve
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: 1250 AP - 40mhz channel selection issue
You need to set the power and the channel before you can enable the 40mhz channel width.
Use one of these for above 40mhz:
36,44,52,60,100,108,116,132,149,157
Use one of these for below 40mhz:
40,48,56,64,104,112,136,153,161
-Scott
-Scott
That worked great. Thanks for your help!
Steve
852
