1250 w/AIR-ANT2430V-R Which cable is antenna A - B - C or does it matter
Please help I have read every doc on this AP and this antenna. there are three jacks on the radio labeled a - b and c. There are three cables on the antenna. which cable corresponds to the correct radio antenna label. Or does it not matter. Looking at the radiation patterns on the antenna I tend to think that it makes a difference. Thanks the info.
Jason
1 ACCEPTED SOLUTION
Re: 1250 w/AIR-ANT2430V-R Which cable is antenna A - B - C or do
The main thing to consider would be that the center cable should be connected to the center jack. The others should not matter as they are the outbound antennae and in mimo the center antenna is the critical unit for phase differentiation. The phase shift mechanisim in the unit will take into effect the other 2 antennae and their position.
1 REPLY
176
