1250AP VLAN config
I am trying to configure VLANs on my 1250 autonomous AP. I have the sub-interfaces setup but still cannot connect to the LAN. I use 432 for my native vlan and then want to assign clients to vlan 543. Being a security guy, I do not use vlan 1, nor do I trunk vlan 1. Here's a snippet of my config, so tell me what I am missing. All interfaces are showing up-up.
Thanks.
int d0
no ip add
int d0.432
encap dot1q 432 native
bridge-group 1
int d0.543
encap dot1q 543
bridge-group 2
int g0
no ip add
int g0.432
bridge-group 1
int g0.543
encap dot1q 543
bridge-group 2
Silver
Re: 1250AP VLAN config
The partial config looks good. Would you be able to post the entire config? Maybe there's a problem with the SSID configuration. Your SSID should show something like:
dot11 ssid SSID_NAME
authentication open
vlan 543
(guest-mode)
Make sure you have "bridge irb" and "bridge 1 route ip" configured. They should be in there by default, but just in case they were removed.
I'd prefer to not post the entire config as it would take a lot of editing. :-)
Both statements are there, and there is no issue with the SSID config. I'm just trying to get a connection to my RADIUS server, which the AP cannot connect to. I am not able to ping the server from the AP, so it has something to do with the vlan config, but I don't know where. The switch where the AP is connected is trunking and allows all vlans (at this point) except for 1.
This is a head scratcher. :-)
Something else of note. I did a sh int g0 on the AP's physical interface and noticed this:
Encapsulation 802.1Q Virtual LAN, Vlan ID 1.
Does this mean that I must TRUNK VLAN 1 on the other end of the switch???
edit: I also noticed the same on the d0 int.
Just found this in the AP documentation:
Under Configuration a VLAN:
"When you configure VLANs on access points, the Native VLAN must be VLAN1"
This puzzles me why you would even be able to specify another vlan as the native vlan if this is the restriction!
Can someone from Cisco clarify this?
134
