You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
1310 Bridge - can it work without an external antenna?
I have 2 1310 outdoor bridges- I can only connect them using external antennas. Is there something wrong in the configuration where im not able to use the internal antenna: attached is the config:
Current configuration : 1371 bytes
version 12.4
no service pad
service password-encryption
no aaa new-model
dot11 ssid 6
vlan 1
authentication open
infrastructure-ssid
dot11 network-map
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 key 1 size 128bit 7 307B2064018D12507336461E467E transmit-key
encryption vlan 1 mode wep mandatory
ssid 6
station-role root bridge
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
interface Dot11Radio0.300
encapsulation dot1Q 300
no ip route-cache
bridge-group 10
interface FastEthernet0
no ip address
no ip route-cache
hold-queue 80 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.300
no ip route-cache
bridge-group 10
interface BVI1
ip address 10.0.3.10 255.255.255.0
no ip route-cache
ip default-gateway 10.0.3.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community public RO
bridge 1 route ip
line con 0
line vty 0 4
login local
end
  • Other Wireless - Mobility Subjects
1 ACCEPTED SOLUTION
Gold
Re: 1310 Bridge - can it work without an external antenna?
The 1310's either have an external antenna connector or an integrated antenna. They don't have both.
The part number AIR-BR1310G-x-K9-R requires and external antenna. AIR-BR1310G-x-K9 has the integrated antenna.
1 REPLY
Gold
139
