1310 Bridge configuration
I have problems configuring a bridge interconnection between two site of a network.
I am using two 1310 APs and two 2960 cisco switches with the following configuration:
version 12.4
no service pad
service password-encryption
hostname xxxxxxx
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
resource policy
ip subnet-zero
dot11 ssid aaaaaaaaaaa
vlan 1
authentication open
infrastructure-ssid
username Cisco password 7 xxxxxxxxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid aaaaaaaaaa
antenna transmit right
antenna receive right
antenna gain 26
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0
power local 20
station-role non-root
cca 75
concatenation
infrastructure-client
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
no snmp trap link-status
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.x.x.x 255.x.x.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
line vty 5 15
login
end
sw1 ---- Bridge1 ------ Bridge2 ------ sw2 ---- PC
The strange thing is that, VLAN 1 is accessible (so also the APs and the switches). I
need to have a trunk link between the two switches to pass the traffic from 7 VLANs. The
native Vlan is 1.
No other traffic crosses the link except that from vlan 1. Even if I set a static IP address
on the computer connected to the second switch. I don't need any radio connections behind the switches,
just a wireless link between both sites.
The configuration of the trunk interfaces on the switches is fine, it is not a big deal...
I guess there is something wrong with the settings on the AP, but I couldn't find what.
Any suggestions or solutions will be appreciated very much. Thanks in advance.
1 REPLY
Bronze
Re: 1310 Bridge configuration
you have to enable those 7 vlans in fastethernet0, for example, if one vlan is 10, then you need to configure:
interface FastEthernet0.10
encapsulation dot1Q 10
bridge-group 10
262
