1310 Bridge with wireless clients configuration
I have a 871W router at the main building and a 1310 in a remote building. The 1310 is currently acting as a "repeater" which gives us a connection back to the main building as well as access for wireless clients near the 1310. I now have a need for both wireless and wired clients near the 1310. To do this I placed the 1310 in the "non-root bridge wirless-client" role. This allowed my wireless clients to connect to the 1310 and reach the main building. The wired clients however cannot reach anything. They do not even pick up a DHCP address. I manually assigned an IP address on a wired client and it could ping the 1310 but nothing beyond the 1310.
Is there a different role I should have set on this radio? I've also tried 3 different versions of IOS, eaching giving me different results. In an older version of IOS this mode would not even let the clients connect wirelessly to the 1310. Since I received different results on each version of IOS I'm not getting a good feeling about this 1310.
Brandon
Below is the configuration of the 1310
service password-encryption
hostname XXXX-1300
enable secret xxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
dot11 syslog
dot11 ssid xxxxwlan
   authentication open
   authentication key-management wpa
   infrastructure-ssid
   wpa-psk ascii xxxxxxxxxxxxxxxxxxxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid xxxxxwlan
station-role non-root bridge wireless-clients
infrastructure-client
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.1.2 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
Re: 1310 Bridge with wireless clients configuration
what VLAN are the wired clients in?  If they are not in the 192.168.2.x subnet, you'll need to trunk across the 1310 to the 871/
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
They are in the 192.168.1.x vlan with the wireless clients. This is a small network so everything is in a single vlan.
Brandon
Today i faced 1 problem, Im doing the outdoor wireless. 1st stage, im using 1 unit AP1310 as a RootAP and client also using AP1310 as a WGB. and have 2 client wired (PLC and PC connect together with AP1310 in 1 switch inside 1 cabin)..Everthing works fine and i can remote is from any company network.
2nd stage (upgrade), my company want to replace RootAP 1310 to Mesh Network with 1 RAP using LWAPP1522 and WLC4400. After configure everything to WLC, i only can remote my AP1310 only and cant remote my PLC and PC as normal. I also cant ping my gateway from PC using AP1310 to network. From the WLC Client, i only can see AP1310 (bridge) the client of bridge not appear. Why ya?
Please help.
Note:
PLC= Programable Logic Control
PC= Cabin Computer
1083
