04-17-2007 12:39 PM - edited 07-03-2021 01:57 PM
Hi guys, I just converted an 1310 AP to LWAPP. When autonomous, it used external antenas, but now under the controller configuration I can't select "external" for the type of antenna. I tried GUI and CLI. I know theres a known bug for the 1500 and 1030 AP regarding this kind of behavior, bout i coulndt find anything about the 1300 Model.
Any suggestions or info?
Thanks in advance!
04-23-2007 08:58 AM
If you set the AP to brigdemode first you wont be able to choose external antenna on the 802.11a radio later (the field where you choose antenna mode will be Omni and you can and change it), but if you set the antenna to external before changing the AP mode to bridge it works.
04-23-2007 09:06 AM
Hi and thanks for the reply.
The 1300 was always configured to act as AP, not as bridge, and that remains the same now workings as LWAPP
