1310 vlans
rodriguesl
I would like to know if it is possible to pass trougth vlans on 2 1310 wireless bridges.
I have a switch1 --> 1310 --> 1310 --> switch2. I want to pass vlans from switch1 to switch2.
How can i do this?
regards
Luís Rodrigues
thomas.chen
Level 6
Level 6
Yes,you can pass the vlan across the AP by making as follows.
1. you should do create a trunk port in two switch and connect the two AP's in those port, so that traffic of different vlan information can pass through trunk port.
2. creat the number of vlan in switches.
Ok. I already tried that and the vlans pass trougth from one side to the other. The problem is when I try to put one port in one of the vlans, i try then to ping another port on that vlan in the other side and it doesn't work.
Can you tell me why this appends?
regards
LR
