1310 weak signal strength with AIR-ANT24120
I have a 1310 bridge with and AIR-ANT24120 external antenna. Problem is that the signal strength is very weak when using this antenna (RSSI -80 -90 for associated clients. I have swapped the antenna for a new one with the same results. I then swapped the antenna for a 2.2 dbi omni and could cover almost 3 times the area. I have changed power settings the dbi assigned to the external antenna etc. The antenna was plugged directly into the 1310 and I am using the 1 foot cable supplied by Cisco for the power injector. I have run out of ideas.
Cisco IOS Software, C1310 Software (C1310-K9W7-M), Version 12.3(8)JA, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 27-Feb-06 09:24 by ssearch
ROM: Bootstrap program is C1310 boot loader
BOOTLDR: C1310 Boot Loader (C1310-BOOT-M) Version 12.3(2)JA3, RELEASE SOFTWARE (fc2)
System image file is "flash:/c1310-k9w7-mx.123-8.JA/c1310-k9w7-mx.123-8.JA"
cisco AIR-BR1310G-A-K9-R (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FOC091827QK
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:14:1C:27:73:F6
Product/Model Number : AIR-BR1310G-A-K9-R
Current configuration : 2425 bytes
version 12.3
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname 1300ap
enable secret 5 <removed>
clock timezone EST -5
ip subnet-zero
no aaa new-model
dot11 ssid <removed>
vlan 99
authentication open
authentication key-management wpa
wpa-psk ascii 7 <removed>
vlan 1
authentication open
guest-mode
mbssid guest-mode
username <removed> privilege 15 password 7 <removed>
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 99 mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid <removed>
ssid <removed>
speed basic-5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root ap-only
rts threshold 4000
cca 75
concatenation
antenna receive right
antenna transmit right
antenna gain 12
world-mode dot11d country US both
infrastructure-client
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.99
encapsulation dot1Q 99
no ip route-cache
bridge-group 99
bridge-group 99 subscriber-loop-control
bridge-group 99 block-unknown-source
no bridge-group 99 source-learning
no bridge-group 99 unicast-flooding
bridge-group 99 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
hold-queue 80 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.99
no ip route-cache
bridge-group 99
interface BVI1
ip address 10.1.5.61 255.255.240.0
no ip route-cache
interface BVI99
no ip address
no ip route-cache
ip default-gateway 10.1.0.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
snmp-server community <removed> RO
control-plane
bridge 1 route ip
1 REPLY
Silver
Re: 1310 weak signal strength with AIR-ANT24120
How many users are there receiving the signal from your antenna?. Let me know this information. Also, did you try using any other antenna apart from the mentioned external antenna?. If yes, then let me know what is the other antenna you tried?.
424
