1310 with AIR-ANT24120 has a weak Signal
I have two building 150 meters away;
one 1310 + air-ant24120
one 1310 internal patch antenna
I cannot align antennas even;
they are directly see each other
they are 150 meters avay
I am not sure "antenna gain" parameters
here is the config of (1310 + air-ant24120)
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 xxx transmit-key
encryption mode ciphers aes-ccm tkip wep128
broadcast-key change 1800 membership-termination capability-change
ssid xxx
antenna transmit right
antenna receive right
antenna gain 28
channel 2427
station-role root bridge
bridge-group 1
bridge-group 1 spanning-disabled
service-policy output ATA-SES
Hall of Fame Super Silver
Re: 1310 with AIR-ANT24120 has a weak Signal
All I can say is make sure the antenna connections are on tight. Also, what is the cable length from the antenna to the 1310 and what type of cable?
-Scott
antenna gain 28
is it true? for 12dbi omni antenna?
444
