1310 Workgroup Bridge no longer recognize WEP key
Hi all,
I have a Cisco 1310 bridge that I am using as a workgroup bridge. It used to work fine until someone made a change and that person is no longer around. I am now left with a paper weight that I need to get working again.
The problem: My infrastructure VLAN (1) is associated with SSID mgt (see config below). I can associate on this VLAN without a problem. However, I cannot associate to VLAN 34 (SSID CHEOTELE). I am getting the following error message: %DOT11-4-ENCRYPT_MISMATCH: Possible encryption key mismatch between interface Dot11Radio0 and station 000f.24e9.de70. I am change the WEP key at both end (in clear or encrypted) and I always get this message. Only the bridge is having the problem because I have other clients who can connect to the AP using the same WEP key.
Any help is welcome...
version 12.2
no service pad
service password-encryption
hostname AV_Bridge
logging queue-limit 100
clock timezone ext -5
ip subnet-zero
no aaa new-model
dot11 network-map
bridge irb
no ip address
no ip route-cache
encryption vlan 34 key 1 size 128bit 7 304856427E9C105764B841693109 transmit-key
encryption vlan 34 mode wep mandatory
encryption vlan 1 key 1 size 128bit 7 CC7F123C7FCB41516184B4774010 transmit-key
encryption vlan 1 mode wep mandatory
ssid CHEOTELE
vlan 34
authentication open
ssid mgt
vlan 1
authentication open
infrastructure-ssid
cca 0
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
rts threshold 4000
power local ofdm 30
station-role workgroup-bridge
infrastructure-client
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio0.34
encapsulation dot1Q 34
no ip route-cache
bridge-group 34
bridge-group 34 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.34
no ip route-cache
bridge-group 34
interface BVI1
ip address 10.0.17.254 255.255.240.0
no ip route-cache
ip default-gateway 10.0.16.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/122-15.JA/1100
bridge 1 route ip
line con 0
line vty 5 15
workgroup-bridge client-vlan 34
end
1 REPLY
Anonymous
N/A
Re: 1310 Workgroup Bridge no longer recognize WEP key
You cannot use PEAP .You have to use either LEAP or created vlans for infrastructure association
256
