1410 Bridge Antenna Option
Can somebody advice me on the antenna options for 1410 bridges. Can I use a 2.4Ghz Antenna for a 1410 bridge ?
1 ACCEPTED SOLUTION
Re: 1410 Bridge Antenna Option
No, you cannot use any of the antennae in the 2.4GHz range. The use of those antennae will not fall within FCC compliance and could cause damage to the radios.
Currently there are only three external 5GHz antennae and of course the one that is internal or "built in" on the 1400's and I believe it is 28dBi directional.
Silver
In order to comply with radio frequency (RF) exposure limits, the antennas for this product should be positioned no less than 6.56 ft (2 m) from your body or nearby persons.
Three optional external bridge antennas
9-dBi omnidirectional external antenna with vertical polarization
9.5-dBi sector external antenna
28-dBi dish external antenna
Thank you. My question is, can I use the 2.4GHz antennas for the 1410 bridges ? We want to replace all the current 350 bridges we have with 1410. Should we buy new 5GHz antennas or can we use the current 2.4GHz antennas but just replace the 350 bridges with the 1410 ? Need advice on that
146
