1410 Bridge needs reboot
I have 2 1410 bridges that have been working with no problem for about 1 year. Recently I started to have issues with throughput. I tried all channels with no help in performance. After I reboot the bridges it seems to work fine. After about a week I seem to have issues again. Has anyone seen these type of issues?
  • Other Wireless - Mobility Subjects
1 REPLY
Anonymous
N/A
Re: 1410 Bridge needs reboot
Performance (throughput) issue, due to various reason:
Adjustingthe CCA and distance will fine tune the radios to that environment.
The DISTANCE parameter needs to be set (in kilometers) to the length of the radio shot between the bridge pair.
The CCA value needs to start at 62. CCA is Clear Channel Assessment, essentially the establishment of a noise floor below which the bridges will ignore RF inputs, in search of a good, solid signal. The default value should be -62 dBi or 62.
Also ensure you have latest IOS version.
112
