08-05-2014 12:59 PM - edited 07-05-2021 01:19 AM
i'm having trouble with a AIR-CAP1552E-A-K9 joining my 4400 controller. i get the following error:
Type of error that occurred last........................... AP got or has been disconnected
Reason for error that occurred last........................ Radius authorization of the AP has failed
note that i only have 'accept manufactured installed certificat' checked under security>ap policies
Solved! Go to Solution.
08-22-2014 07:33 AM
Normall it comes with mesh image.
On the logs ": Radius authorization of the AP has failed " means that this needs the MAC address to be in the mac filter or ap policies.
So, from WLC GUI>>Secuirty>>AAA>AP policies>>Add> (AP mac addr) and check if it joins.
Dont forget to rate helpful posts
08-05-2014 01:11 PM
Pls attached the console output of your AP while booting & trying to associate to your WLC. THat will tell us more about why it cannot register to your WLC.
I believe you are running 7.0.116.0 or above on your WLC
Rasika
**** Pls rate all useful responses ****
08-05-2014 01:22 PM
i dont have access to the AP console. Here is what i see on cdp:
Version :
Cisco IOS Software, C1550 Software (C1520-K9W8-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
4400 controller:
Product Version.................................. 7.0.240.0
08-05-2014 01:56 PM
AP console output is required to tell exactly what's going on..
Rasika
08-22-2014 07:33 AM
08-22-2014 06:28 AM
the self-signed certificate (SSC) of the AP was not correct on the controller. The controller always checks its local database before it forwards the request to a defined radius server. As a result, the RADIUS authorization is pending for AP error appears when the controller does not find the SSC locally.
