Community Member
1801w ISR and mapping VLAN, WLAN and VRF
I have a problem with getting SSID and local vlans to work unless I create subinterfaces on radio interface. If the VLAN is then associated to a VRF and VRF DHCP pool I won?t get an IP over WLAN.
Has anyone experience with such a solution with the intergrated radio?
Using LWAPP Hybrid REAP AP?s on a trunk (fa8) interface works just fine...
1 REPLY
Silver
Re: 1801w ISR and mapping VLAN, WLAN and VRF
Try the command ip dhcp use vrf connected in order to assign the ip address through DHCP.
233
