1841 in Universal Client Mode
I am trying to make my 1841 Router (with HWIC-AP card) work in Universal Client Mode (not bridging!!). I have tried to configure as per this (there seems to be very little document on this out there :( )
http://www.cisco.com/en/US/docs/routers/access/1800/wireless/configuration/guide/s37rf.html#wp1134667
From the 1242AP, I am only able to ping to the dot11 interface on the Router, not to the Fa 0/0 or the Router
Any suggestions will be helpful, Thanks
Configuration on 1242AP:
dot11 ssid Cisco
authentication open
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid Cisco
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root access-point
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.1.10 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.254
bridge 1 protocol ieee
bridge 1 route ip
Configuration on 1841 Router:
dot11 ssid Cisco
authentication open
infrastructure-ssid
ip dhcp excluded-address 172.16.1.1
ip dhcp pool BMX
network 172.16.1.0 255.255.255.0
default-router 172.16.1.1
interface FastEthernet0/0
ip address 172.16.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
no keepalive
interface Dot11Radio0/0/0
ip address 192.168.1.70 255.255.255.0
ip nat outside
no ip route-cache
ssid Cisco
54.0
station-role non-root
ip route 0.0.0.0 0.0.0.0 Virtual-Dot11Radio0
ip nat inside source list 1 interface Virtual-Dot11Radio0 overload
access-list 1 permit any
  • Other Wireless - Mobility Subjects
Re: 1841 in Universal Client Mode
under the SSID on the 1242, add infrastucture-ssid optional
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
This problem has been solved now. It seems to be a minor NATing issue. I removed permit any and replaced with inside subnet in the access-list. According to Cisco, you do not configure access lists referenced by NAT commands with permit any. Using permit any can result in NAT consuming too many router resources which can cause network problems.
ip route 0.0.0.0 0.0.0.0 192.168.1.254
access-list 1 permit 172.16.1.0 0.0.0.255
511
