03-05-2014 06:20 AM - edited 07-05-2021 12:20 AM
5508 WLC (7.5.102)
AP36021
We currently have a test WiFi SSID setup that uses basic mac filtering on our WLC's
WLAN is configured with WPA and WPA2 L2 Security with WPA Policy and WPA2 Encryption.
For some reason we seem to be getting very slow speeds on clients with 2.4GHZ
for example speedtest.net I get 70mg upload and 65mg download on 5GHZ devices and about 1-3mg download and 1mg upload for 2.4GZ devices!
AP36021 are dual band with 4 channels (2 x 2.4Ghz and 2 x 5Ghz)
fyi - There are no dropped packets on the client stats via Prime mgmt that use 2.4GHZ
Any ideas here?
03-06-2014 11:21 PM
sh int gi4/32
GigabitEthernet4/32 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0015.c634.4fbf (bia 0015.c634.4fbf)
Description: ukgre05-051-a36
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseT
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 00:00:02, output 00:00:35, output hang never
Last clearing of "show interface" counters 41w6d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 1000 bits/sec, 1 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
124898544 packets input, 27675117366 bytes, 0 no buffer
Received 1317350 broadcasts (892533 multicasts)
0 watchdog, 0 multicast, 0 pause input
193076170 packets output, 112790254666 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
03-07-2014 02:03 AM
As you can see, your AP connected port is negotiated to 100Mbps. Ideally it should be negotiated to 1Gbps. Just use "speed auto" without any values, then port will be negotiated to 1Gbps.
This is important specially your AP is 3600 which can provide upto 450Mbps throughput. Depend on the client number of spatial stream you can get below data rates. In 2.4GHZ BW is 20MHz you can go upto 195Mbps (with GI 800ns) max with 3 SS client.
First makesure you have corrected that issue. If you get "show client detail
Rasika
**** Pls rate all useful responses ****
03-07-2014 03:05 AM
Hi Rasika,
port now changed
sh int status | i 4/32
Gi4/32 cisco-a36 connected 30 a-full a-1000 10/100/1000BaseT
I suppose the link could be saturated and that's a very basic error on my part!
The persons that are taking part in my tests with 2.4GHZ devices are away today, I'll send feedback Monday with speed results.
Thanks.
03-05-2014 10:35 AM
can you post show client details
12-06-2018 03:35 AM
I know this is an old thread, but was there any feedback on the fix for this issue - we have very similar issue?
