Community Member
2.4GHZ clients very slow speeds with AP3600
5508 WLC (7.5.102)
AP36021
We currently have a test WiFi SSID setup that uses basic mac filtering on our WLC's
WLAN is configured with WPA and WPA2 L2 Security with WPA Policy and WPA2 Encryption.
For some reason we seem to be getting very slow speeds on clients with 2.4GHZ
for example speedtest.net I get 70mg upload and 65mg download on 5GHZ devices and about 1-3mg download and 1mg upload for 2.4GZ devices!
AP36021 are dual band with 4 channels (2 x 2.4Ghz and 2 x 5Ghz)
fyi - There are no dropped packets on the client stats via Prime mgmt that use 2.4GHZ
Any ideas here?
VIP Purple
paste sh wlan
and the paste swicth port config where WLC and AP connected
Community Member
Re: 2.4GHZ clients very slow speeds with AP3600
Foreign Primary WLC (let me know if you need the Anchor controller ouput as well)
We have 3 ports configured  as 0/12 trunked
interface GigabitEthernet0/12
description + WLC ****
switchport access vlan 999
switchport trunk native vlan 999
switchport trunk allowed vlan 10,30,40
switchport mode trunk
switchport nonegotiate
load-interval 30
no cdp enable
channel-group 3 mode on
spanning-tree portfast
end
Building configuration...
Current configuration : 330 bytes
interface Port-channel3
logging event trunk-status
logging event bundle-status
load-interval 30
end
AP switch port config
Current configuration : 617 bytes
interface GigabitEthernet4/32
description AP36021
switchport
switchport access vlan 30
switchport mode access
switchport voice vlan 20
load-interval 30
speed auto 10 100
wrr-queue bandwidth 5 90 5
wrr-queue queue-limit 5 80 5
wrr-queue random-detect min-threshold 2 70 100 100 100 100 100 100 100
wrr-queue random-detect min-threshold 3 70 100 100 100 100 100 100 100
wrr-queue random-detect max-threshold 2 100 100 100 100 100 100 100 100
wrr-queue cos-map 2 1 0 1 2 4
wrr-queue cos-map 3 1 3 6 7
no snmp trap link-status
mls qos trust cos
no mdix auto
end
show wlan 4
WLAN Identifier.................................. 4
Profile Name..................................... WLKPV
Network Name (SSID).............................. WLKPV
Status........................................... Enabled
MAC Filtering.................................... Enabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
Number of Active Clients......................... 21
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 7200 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 12 hours
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... hellotest
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ new-byod
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
    PMIPv6 MAG Profile........................... Unconfigured
    PMIPv6 Default Realm......................... Unconfigured
--More-- or (q)uit
    PMIPv6 NAI Type.............................. Hexadecimal
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
--More-- or (q)uit
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
      Framed IPv6 Acct AVP ...................... Prefix
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
--More-- or (q)uit
      Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Enabled
   FlexConnect Local Switching................... Disabled
--More-- or (q)uit
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Split Tunnel (Printers).......................... Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
--More-- or (q)uit
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
4           10.x.x.x          Up
4           10.x.x.x         Up
802.11u........................................ Disabled
MSAP Services.................................. Disabled
VIP Purple
load-interval 30
no cdp enable
end
load-interval 30
end
Can you try to remove this command from port and etherchannel:
Hall of Fame Super Silver
Can be also channel utilization. Use iperf to test in your local network.
-Scott
Community Member
Client Iperf
Server listening on TCP port 5001
TCP window size:  256 KByte (WARNING: requested  250 KByte)
TCP window size:  256 KByte (WARNING: requested  256 KByte)
Client connecting to 192.168.1.199, TCP port 5001
[  7] local 192.168.9.152 port 47166 connected with 192.168.1.199 port 5001
[  8] local 192.168.9.152 port 47167 connected with 192.168.1.199 port 5001
[ 12] local 192.168.9.152 port 47169 connected with 192.168.1.199 port 5001
[ 11] local 192.168.9.152 port 47168 connected with 192.168.1.199 port 5001
connect failed: Connection refused
[ 11] local 192.168.9.152 port 47180 connected with 192.168.1.199 port 5001
[  6] local 192.168.9.152 port 47177 connected with 192.168.1.199 port 5001
[  7] local 192.168.9.152 port 47178 connected with 192.168.1.199 port 5001
[  8] local 192.168.9.152 port 47179 connected with 192.168.1.199 port 5001
[  5] local 192.168.9.152 port 47176 connected with 192.168.1.199 port 5001
[ 12] local 192.168.9.152 port 47181 connected with 192.168.1.199 port 5001
Waiting for server threads to complete. Interrupt again to force quit.
[ ID] Interval       Transfer     Bandwidth[  5]  0.0-63.8 sec  1.25 MBytes   164 Kbits/sec[  6]  0.0-66.1 sec  1.88 MBytes   238 Kbits/sec
[  8]  0.0-67.5 sec  1.00 MBytes   124 Kbits/sec[ 11]  0.0-68.6 sec  2.00 MBytes   244 Kbits/sec
[ 12]  0.0-69.1 sec  2.38 MBytes   288 Kbits/sec
[SUM]  0.0-69.1 sec  9.75 MBytes  1.18 Mbits/sec
------------------------------[ 11] local 192.168.9.152 port 47186 connected with 192.168.1.199 port 5001
[  5] local 192.168.9.152 port 47182 connected with 192.168.1.199 port 5001
[  6] local 192.168.9.152 port 47183 connected with 192.168.1.199 port 5001
[  8] local 192.168.9.152 port 47185 connected with 192.168.1.199 port 5001
[ 12] local 192.168.9.152 port 47187 connected with 192.168.1.199 port 5001
[  7] locWaiting for server threads to complete. Interrupt again to force quit.[ ID] Interval       Transfer     Bandwidth
[  8]  0.0-66.5 sec  1.62 MBytes   205 Kbits/sec
[  7]  0.0-66.5 sec  1.12 MBytes   142 Kbits/sec
[ 11]  0.0-66.6 sec  1.88 MBytes   236 Kbits/sec
[  6]  0.0-66.7 sec  1.38 MBytes   173 Kbits/sec
[ 12]  0.0-75.3 sec  1.75 MBytes   195 Kbits/sec
[  5]  0.0-82.5 sec  1.38 MBytes   140 Kbits/sec
[SUM]  0.0-82.5 sec  9.12 MBytes   927 Kbits/sec
Serve Iperf
TCP window size:  512 KByte (WARNING: requested  256 KByte)
[  4] local 192.168.1.199 port 5001 connected with 192.168.9.152 port 47176
[  6] local 192.168.1.199 port 5001 connected with 192.168.9.152 port 47179
[  7]  0.0-66.1 sec  1.25 MBytes   159 Kbits/sec
[ 13] local 192.168.1.199 port 49124 connected with 192.168.9.152 port 5001
Client connecting to 192.168.9.152, TCP port 5001
[  5]  0.0-67.5 sec  1.88 MBytes   233 Kbits/sec
[ 20] local 192.168.1.199 port 49132 connected with 192.168.9.152 port 5001
[ 17] local 192.168.1.199 port 49129 connected with 192.168.9.152 port 5001
[  7] local 192.168.1.199 port 49128 connected with 192.168.9.152 port 5001
[ 19] locconnect failed: Connection refusedconnect failed: Connection refused
[  9]  0.0-71.8 sec  2.38 MBytes   277 Kbits/sec
[  6]  0.0-71.9 sec  1.00 MBytes   117 Kbits/sec
[ 10]  0.0-71.9 sec  2.00 MBytes   233 Kbits/sec
[SUM]  0.0-71.9 sec  9.75 MBytes  1.14 Mbits/sec
connecconnect failed: Connection refused
connect failed: Connection refusconnect failed: Connection refused
-------------------------------------[  4] local 192.168.1.199 port 5001 connected with 192.168.9.152 port 47182[  5] local 192.168.1.199 port 5001 connected with 192.168.9.152 port 47183
[  9] local 192.168.1.199 port 5001 connected with 192.168.9.152 port 47187
[  6] local 192.168.1.199 port 5001 connected with 192.168.9.152 port 47184
[  7] local 192.168.1.199 port 5001 connected with 192.168.9.152 port 47185
[ 10] local 192.168.1.199 port 5001 connected with 192.168.9.152 port 47186
[ 11] local 192.168.1.199 port 5001 connected with 192.168.9.148 port 52846
[ 18] local 192.168.1.199 port 5001 connected with 192.168.9.148 port 52850
[ 10]  0.0-69.8 sec  1.88 MBytes   225 Kbits/sec
[ 19] local 192.168.1.199 port 5001 connected with 192.168.9.148 port 52849
[ 31] local 192.168.1.199 port 5001 connected with 192.168.9.148 port 52847
[ 32] local 192.168.1.199 port 5001 connected with 192.168.9.1[  5]  0.0-70.0 sec  1.38 MBytes   165 Kbits/sec
[  6]  0.0-70.3 sec  1.12 MBytes   134 Kbits/sec
[ 16] local 192.168.1.199 port 49167 connected with 192.168.9.152 port 5001
[ 13] local 192.168.1.199 port 49162 connected with 192.168.9.152 port 5001
[ 14] local 192.168.1.199 port 49165 connected with 192.168.9.152 port 5001
[ 15] local 192.168.1.199 port 49166 connected with 192.168.9.152 port 5001
[  7] local 192.168.1.199 port 49161 connected with 192.168.9.152 port 5001
[ 12] local 192.168.1.199 port 49163 connected with 192.168.9.152 port 5001
[ 24] local 192.168.1.199 port 49173 connected with 192.168.9.152 po------------------------------------------------------------
Community Member
Server was on 5GHZ
Cient on 2.4GHZ
Can you post a client to server on both the 5ghz and then one with both on the 2.4ghz.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Community Member
Scott, as requested.....
Server 5GHZ
[  4] local 192.168.9.158 port 5001 connected with 192.168.1.190 port 37085
[  7] local 192.168.9.158 port 5001 connected with 192.168.1.190 port 37083[ ID] Interval       Transfer     Bandwidthconnect failed: Connection refused[  4]
0.0-62.4 sec  8.75 MBytes  1.18 Mbits/sec
[  9]  0.0-62.5 sec  11.1 MBytes  1.49 Mbits/sec
[ 10]  0.0-62.6 sec  10.2 MBytes  1.37 Mbits/sec
[  6]  0.0-62.7 sec  6.88 MBytes   920 Kbits/sec
[SUM]  0.0-62.7 sec  55.9 MBytes  7.48 Mbits/sec
Client 5GHZ
/data/data/com.magicandroidapps.iperf/bin/iperf: ignoring extra argument -- Iperf
connect failed: No route to host
Client connecting to 192.168.9.158, TCP port 5001
[  5] local 192.168.1.190 port 37082 connected with 192.168.9.158 port 5001
[ 10] local 192.168.1.190 port 37086 connected with 192.168.9.158 port 5001
[  9] local 192.168.1.190 port 37085 connected with 192.168.9.158 port 5001
[  8] local 192.168.1.190 port 37084 connected with 192.168.9.158 port 5001
[  7] local 192.168.1.190 port 37083 connected with 192.168.9.158 port 5001
[ 11] local 192.168.1.190 port 37087 connected with 192.168.9.158 port 5001
[  5]  0.0-60.4 sec  11.1 MBytes  1.55 Mbits/sec
[  7]  0.0-60.4 sec  10.2 MBytes  1.42 Mbits/sec
[  8]  0.0-60.4 sec  10.2 MBytes  1.42 Mbits/sec
[ 11]  0.0-60.5 sec  6.88 MBytes   953 Kbits/sec
[  9]  0.0-60.7 sec  8.75 MBytes  1.21 Mbits/sec
[SUM]  0.0-60.7 sec  55.9 MBytes  7.73 Mbits/sec
Server 2.4GHZ
[  4] local 192.168.9.158 port 5001 connected with 192.168.9.152 port 55672[  5] local 192.168.9.158 port 5001 connected with 192.168.9.152 port 55673
[  6] local 192.168.9.158 port 5001 connected with 192.168.9.152 port 55674
[  7] local 192.168.9.158 port 5001 connected with 192.168.9.152 port 55670
[ 10] local 192.168.9.158 port 5001 connected with 192.168.9.152 port 55671
[  7]  0.0-98.4 sec   768 KBytes  63.9 Kbits/sec
------------------------------------------------------------[  7] local 192.168.9.158 port 60640 connected with 192.168.9.152 port 5001
[  6]  0.0-127.9 sec   384 KBytes  24.6 Kbits/sec
[ 16]  0.0-60.0 sec  88657964739271040 bits  0.00 (null)s/sec
[ 14]  0.0-60.0 sec  86059324842202368 bits  0.00 (null)s/sec
[ 12]  0.0-60.0 sec  67923022280180696 bits  0.00 (null)s/sec
[ 13]  0.0-60.0 sec  76932626714509728 bits  0.00 (null)s/sec
[ 15]  0.0-60.0 sec  74023593825998688 bits  0.00 (null)s/sec
[  7]  0.0-60.0 sec  79947667985795968 bits  0.00 (null)s/sec
[SUM]  0.0-60.0 sec  473544200387958464 bits  0.00 (null)s/sec
Client 2.4GHZ
Client connecting to 192.168.9.158, [  7] local 192.168.9.152 port 55671 connected with 192.168.9.158 port 5001
[  8] local 192.168.9.152 port 55672 connected with 192.168.9.158 port 5001
[ 11] local 192.168.9.152 port 55673 connected with 192.168.9.158 port 5001
[ 12] local 192.168.9.152 port 55674 connected with 192.168.9.158 port 5001
[  5] local 192.168.9.152 port 55669 connected with 192.168.9.158 port 5001
[  6] local 192.168.9.152 port 55670 connected with 192.168.9.158 port 5001
[  7]  0.0-62.9 sec   512 KBytes  66.7 Kbits/sec
[  6]  0.0-69.8 sec   768 KBytes  90.1 Kbits/sec
[ 11]  0.0-70.5 sec   384 KBytes  44.6 Kbits/sec
[ 12]  0.0-72.2 sec   384 KBytes  43.6 Kbits/sec
[  5]  0.0-72.4 sec   256 KBytes  29.0 Kbits/sec
[  8]  0.0-321.1 sec   331 KBytes  8.44 Kbits/sec
[SUM]  0.0-321.1 sec  2.57 MBytes  67.2 Kbits/sec
Looks like you have issues on both bands... you should not see the following:
If you do a file transfer using FileZilla or and FTP client that does show the transfer rate, can you perform the same test... both on the 2.4ghz and both on the 5ghz.
Also post your show wlan
Seems like you have an issue in the network or a configuration issue.
Scott
-Scott
Community Member
Here is the WLAN - I'll organise file transfer soon.
>show wlan 4
Profile Name..................................... TEST
Network Name (SSID).............................. TEST
--More-- or (q)uit
Number of Active Clients......................... 24
NAS-identifier................................... WLC
--More-- or (q)uit
--More-- or (q)uit
Radius Servers
Security
--More-- or (q)uit
      Auth Key Management
--More-- or (q)uit
--More-- or (q)uit
4           10.x.x.100          Up
4           10.x.x.101          Up
Local Policy
Priority  Policy Name
Okay... so you are anchoring.... can you test with an ssid that is not being anchored... need to get some baselines.
Scott
-Scott
Community Member
I setup a TEST WLAN on the Foreign WLC only results as below
5GHZ server
[  4] local 10.136.8.173 port 5001 connected with 10.136.11.245 port 1918[  5] local 10.136.8.173 port 5001 connected with 10.136.11.245 port 1917
[  4]  0.0-61.7 sec  14.5 MBytes  1.97 Mbits/sec
Client connecting to 10.136.11.245, TCP port 5001
[ 10]  0.0-64.2 sec  15.2 MBytes  1.99 Mbits/sec[  7]  0.0-64.3 sec  15.4 MBytes  2.01 Mbits/sec
[  5]  0.0-64.3 sec  15.4 MBytes  2.00 Mbits/sec
[  9]  0.0-64.3 sec  15.4 MBytes  2.00 Mbits/sec
[  6]  0.0-64.3 sec  15.4 MBytes  2.00 Mbits/sec
[SUM]  0.0-64.3 sec  91.2 MBytes  11.9 Mbits/sec
5GHZ client
C:\iperf>iperf -c 10.136.8.173 -P 6 -w 256k -r -t 60
Client connecting to 10.136.8.173, TCP port 5001
[  7] local 10.136.11.245 port 1919 connected with 10.136.8.173 port 5001
[  8] local 10.136.11.245 port 1920 connected with 10.136.8.173 port 5001
[  9] local 10.136.11.245 port 1921 connected with 10.136.8.173 port 5001
[  5] local 10.136.11.245 port 1917 connected with 10.136.8.173 port 5001
[  6] local 10.136.11.245 port 1918 connected with 10.136.8.173 port 5001
[  3] local 10.136.11.245 port 1916 connected with 10.136.8.173 port 5001
[  6]  0.0-57.8 sec  14.5 MBytes  2.10 Mbits/sec
[  6] local 10.136.11.245 port 5001 connected with 10.136.8.173 port 58804
[ 10] local 10.136.11.245 port 5001 connected with 10.136.8.173 port 58806
[ 11] local 10.136.11.245 port 5001 connected with 10.136.8.173 port 58807
[ 12] local 10.136.11.245 port 5001 connected with 10.136.8.173 port 58808
[ 13] local 10.136.11.245 port 5001 connected with 10.136.8.173 port 58809
[  7]  0.0-60.6 sec  15.2 MBytes  2.11 Mbits/sec
[  9]  0.0-60.7 sec  15.4 MBytes  2.12 Mbits/sec
[  5]  0.0-60.7 sec  15.4 MBytes  2.12 Mbits/sec
[  8]  0.0-60.8 sec  15.4 MBytes  2.12 Mbits/sec
[  3]  0.0-60.8 sec  15.4 MBytes  2.12 Mbits/sec
[SUM]  0.0-60.8 sec  91.2 MBytes  12.6 Mbits/sec
[  3] local 10.136.11.245 port 5001 connected with 10.136.8.173 port 58810
2.4GHZ client
Client connecting------------------------------------------------------------
[ 12] local 10.136.9.98 port 32839 connected with 10.136.8.173 port 5001
[  5] local 10.136.9.98 port 32834 connected with 10.136.8.173 port 5001
[  7] local 10.136.9.98 port 32836 connected with 10.136.8.173 port 5001
[  8] local 10.136.9.98 port 32837 connected with 10.136.8.173 port 5001
[  6] local 10.136.9.98 port 32835 connected with 10.136.8.173 port 5001
[ 11] local 10.136.9.98 port 32838 connected with 10.136.8.173 port 5001
Waiting for server threads to complete. Interrupt again to force quit.[ ID] Interval       Transfer     Bandwidth[  8]  0.0-93.3 sec   384 KBytes  33.7 Kbits/sec
[  7]  0.0-95.7 sec   384 KBytes  32.9 Kbits/sec[  6]  0.0-120.6 sec   384 KBytes  26.1 Kbits/sec
[  5]  0.0-124.6 sec   384 KBytes  25.3 Kbits/sec
2.4GHZ server (timed out)
[  4] local 10.136.8.173 port 5001 connected with 10.136.9.98 port 32834[  5] local 10.136.8.173 port 5001 connected with 10.136.9.98 port 32836
[  6] local 10.136.8.173 port 5001 connected with 10.136.9.98 port 32837
[  7] local 10.136.8.173 port 5001 connected with 10.136.9.98 port 32835
[  9] local 10.136.8.173 port 5001 connected with 10.136.9.98 port 32838
[ 10] local 10.136.8.173 port 5001 connected with 10.136.9.98 port 32839
VIP Purple
Post the output of "show interface g4/32" as I would like to see it is negotiate to 1Gbps.
The command you entered  "speed auto 10 100" under G4/32 may limit the port speed to 100Mbps.
Rasika
**** Pls rate all useful responses ****
Community Member
Speed is now a-1000mb on the
Speed is now a-1000mb on the AP.
Still the same problem, in fact with the Andriod and Apple devices we are now getting >1mb upload and >1mb download with 2.4ghz via speedtest.net
My device 5GHZ i get 70mg download and 65mg upload via speedtest.net (Android)
Community Member
sh int gi4/32
GigabitEthernet4/32 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0015.c634.4fbf (bia 0015.c634.4fbf)
  Description: ukgre05-051-a36
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 00:00:02, output 00:00:35, output hang never
  Last clearing of "show interface" counters 41w6d
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 1000 bits/sec, 1 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     124898544 packets input, 27675117366 bytes, 0 no buffer
     Received 1317350 broadcasts (892533 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     193076170 packets output, 112790254666 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
VIP Purple
As you can see, your AP connected port is negotiated to 100Mbps. Ideally it should be negotiated to 1Gbps. Just use "speed auto" without any values, then port will be negotiated to 1Gbps.
This is important specially your AP is 3600 which can provide upto 450Mbps throughput. Depend on the client number of spatial stream you can get below data rates. In 2.4GHZ BW is 20MHz you can go upto 195Mbps (with GI 800ns) max with 3 SS client.
First makesure you have corrected that issue. If you get "show client detail " output it will show you at what MCS data rate client get connected.
Rasika
Community Member
Hi Rasika,
port now changed
sh int status | i 4/32
Gi4/32       cisco-a36    connected    30         a-full a-1000 10/100/1000BaseT
I suppose the link could be saturated and that's a very basic error on my part!
The persons that are taking part in my tests with 2.4GHZ devices are away today, I'll send feedback Monday with speed results.
Thanks.
can you post show client details
775
